07-18-2010 11:12 AM - edited 03-15-2019 11:47 PM
The customer has 2 E1 ports in HQ and an IPCC system and want to reserve 15 channels from the first E1 to be always available for IPCC inbound and outbound...is it possible...and if so what should be the GW type "MGCP, H323" and configuration required.
07-18-2010 01:51 PM
Do you mean 2 E1s from Telco company? if that then only the telco can do this.
07-18-2010 01:59 PM
The telecom "and not in my country I think " can do it for inbound calls...what about outboud calls??
07-18-2010 04:04 PM
I think for out going calls it is easy, while 15 channels = 1 voice port so you can control this voice port through the dial-peer
but how you will manage the incoming calls
07-18-2010 04:07 PM
15 Channel is half port :)...that is the delmma
Disclaimer: NOTICE The information contained in this message is confidential and is intended for the addressee(s) only. If you have received this message in error or there are any problems please notify the originator immediately. The unauthorized use, disclosure, copying or alteration of this message is strictly forbidden. Raya will not be liable for direct, special, indirect or consequential damages arising from alteration of the contents of this message by a third party or as a result of any malicious code or virus being passed on. Views expressed in this communication are not necessarily those of Raya.If you have received this message in error, please notify the sender immediately by email, facsimile or telephone and return and/or destroy the original message.
07-18-2010 04:29 PM
0/0/0:0
and
0/0/0:1
