IPCC script and holidays.xml file
Folks,
I have a problem. I keep updating the holidays.xml file and then when i reboot the server all my changes are gone in that file???
Re: IPCC script and holidays.xml file
What version of IPCC? Is it express or Enterprise or System? What version? High availability?
For Example, if you are using IPCC express with 4.0 with high availability you may have a replication issue. or may not be updating to the repository correctly.
express and no failover, but the script still reverts to the old version everytime i do i reboot to the callmanager(ipcc coresident).
271
