iPhone Cisco mobile 8 integration with CME
  I have set up Cisco 8 Mobile for iPhone and am able to call between the iPhones DNs and Desk phone DNs but how do I  enable ability to see on an iPhone when I have an external call coming in? Also I am unable to make make external calls, does the iPhone use the same dial-peers?
Thanks for your help. : )
Everyone's tags (5)
Re: iPhone Cisco mobile 8 integration with CME
Do you mean mobility??
And yes, it uses the same dial plan and config as an other phone for outbound calls
java
if this helps, please rate
www.cisco.com/go/pdi
Yup I meant mobility, I just read that Jabber is the latest instance of Cisco Mobility. I will test that and see how I get on. How do I get my external calls thou to the iPhone using jabber?
194
