IPIPGW -- H.323 to SIP Issue
I have an issue with an IPIPGW that has an H323 trunk to one CCM cluster and a SIP trunk to another CCM cluster.
When I place a call from the SIP side to the H323 side? when the call is answered the calling party continues to hear ringing while the called party hears dead air. When the calling party hangs up the call ends on both sides.
This seems to work fine if I configure the IPIPGW to do H323-to-H323 so I?m fairly certain there?s an issue with the SIP trunk.
I?ve included the output of <debug ccsip messages> from the IPIPGW.
*Jun 23 00:41:05.743: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:301386@X.X.130.21:5060 SIP/2.0
Via: SIP/2.0/TCP X.X.130.12;branch=z9hG4bK40270b9add
Remote-Party-ID: <sip:2055551212@X.X.130.12>;party=calling;screen=yes;privacy=off
From: <sip:2055551212@X.X.130.12>;tag=ea851b51-b52c-4abf-9739-47537c0677ef-27435069
To: <sip:301386@X.X.130.21>
Date: Fri, 22 Jun 2007 23:30:18 GMT
Call-ID: 8809e680-67c15b8a-35-c82280a@X.X.130.12
Supported: timer,replaces
Min-SE: 1800
User-Agent: Cisco-CCM5.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Contact: <sip:2055551212@X.X.130.12:5060;transport=tcp>
Expires: 180
Allow-Events: presence, kpml
Call-Info: <sip:X.X.130.12:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Session-Expires: 1800
Max-Forwards: 70
Content-Length: 0
*Jun 23 00:41:05.755: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <sip:301386@X.X.130.21>;tag=B09735C-F9C
Date: Sat, 23 Jun 2007 00:41:05 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Allow-Events: telephone-event
Content-Length: 0
*Jun 23 00:41:05.783: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Contact: <sip:301386@X.X.130.21:5060;transport=tcp>
Content-Length: 0
*Jun 23 00:41:15.883: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
CSeq: 101 INVITE
Reason: Q.850;cause=16
Content-Length: 0
*Jun 23 00:41:15.887: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:301386@X.X.130.21:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Re: IPIPGW -- H.323 to SIP Issue
Did you resolve this issue? I'm experiencing the same problem
Bronze
Make sure you check the "Enable Inbound Faststart" box on the H323 trunk config page.
I solve a similar problem with the Inbound & Outbound fast start enabled with G.729 codec and MTP required on the GW configuration. MTP software configured into the IPIPGW
Hope this help.
186
