IPIPGW vs CUBE
Dears:
I have been implemented IPIPGW(12.4T)  with callmanager express 4.0 but now I tried to implement IPIPGW(12.4T) with CME 7.0 and does not work. I started to search about IPIPGW interoperability with CME and found information some information about CUBe that confuse me:
- Is CUBE an evolution of IPIPGW?
-There is some restrictions to use IPIPGW(12.4T) wit new CME releases?
Please if someone can tell me what info i can read or explain me something.
Thanks for your help
Best Regards
Marcelo
1 REPLY
Re: IPIPGW vs CUBE
As it was before CCM and it's now CUCM same with IPIPGW, it has turned into CUBE.
Since 12.4(15)XZ and 12.4(20)T the CUBE license is enforced, soi f you intend to use the feature you need to buy a CUBE license.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
479
