IPMA and 7985 Phone
I have some managers with 7985 and I need to know if I can configure the IPMA for them.7.1(2)
I referred to Cisco Unified Communications Manager Features and Services Guide
The following phones that are running SCCP support Cisco Unified Communications Manager Assistant:
•Cisco Unified IP Phone 7970/71
•Cisco Unified IP Phone 7960/61
•Cisco Unified IP Phone 7940/41
as you can see the document is not updated well, So any body tested it 798
1 REPLY
Green
Re: IPMA and 7985 Phone
7985 is not supported by IPMA and the information provided in the links
(for IPMA documentation) is correct.
There was a confusion between phone and IPMA teams because of which you
see a contradiction between their docs.
The reason that IPMA does not support these phones is - not enough lines
to configure phones for Manager/Assistant. Though there are ways to have more lines in the model but User experience as a whole gets affected,
due to which IPMA does not has any immediate plan to provide support for
these phones.
139
