Silver
IPMA and EM
I have the following:
IPMA and the manager has a 7970
When I configure the manager with a device name (SEPXXX) it works, I have the icons on the screen.
However when I try to configure the manager to use a device profile, I never see the icons on the screen. I restarted the IPMA service several times, but it seems that when I select the device profile it wont work.
According to the manual EM should work for the managers.
I am using CM 6.1.2
Any idea?
JH
Anonymous
N/A
Re: IPMA and EM
check for the following configurations:
- "Mobile Manager" check box is checked at Manager Configuration Page.
- EM Device Profile is selected in the drop down for "Device Name/Profile" (and not the static phone) at Manager Configuration Page.
- The EM Device Profile is configured with Softkey template for IPMA Standard Manager.
- The EM Device Profile is subscribed to IPMA Phone service.
Silver
Re: IPMA and EM
This was all correct, but finally after a reboot of CM it worked.
when making a small change you have to restart the IPMA service, and after many restarts it seems completely unstable, only a reboot clears up the mess.
I shall make an upgrade to 6.1.3 to see if IPMA is more stable.
Jan
124
