IPMA Console
Hi all,
I'm using CUCM 6.1.2 with IPMA feature.
For Directory search, we are using a third party directory server, not a CallManagger Directory.
From the IPMA Console, I would like to force the Directory search to use the third party server and d not the native CallManager Directory, do you have any idea to do this ?
Thanks for your help,
/AN
Silver
Re: IPMA Console
You can access the CM directory from the IPMA console.If the assistant needs access to a corporate directory (accessing Cisco CallManager interclusters), you must update the LDAPConfig.ini file and store it on the primary and backup IPMA servers.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmfeat/fsipma.html#wp1072523
Re: IPMA Console
Thanks a lot for your response,
I'm using a CCM6.1.2 and i can't get the file "LDAPConfig.ini" :(
do you have any idea ?
Best,
/AN
124
