IPMA DivAll
hi
i have configured IPMA in proxy mode everything is ok and fine except one thing. it is that Divert all does not work, when toggeling Divall on assistant application or on manager's phone it appears with the correspoding arrow to appear in Divall mode, but it does not work, once any one called the manager CTI forwards him directly to the manager..
did any one encounter like this problem ...
i did restarted CTI RP and IPMA service with same result
please help
thanks
Re: IPMA DivAll
Do you have any filters in place ?
Re: IPMA DivAll
there r neither inclusive nor exclusive filters ...!!
Green
Re: IPMA DivAll
CSS and partitions are well configured?
IPMA RP have the manager partition?
and under Service Parameters all is good?
If you have both call filtering and DivAll enabled, Cisco IPMA first applies call filtering to an incoming call. Call filtering directs the call to you or to your assistant (depending on filter settings.) Next, Cisco IPMA applies DivAll to those calls that filtering has directed to you. The DivAll feature redirects those calls to the DivAll target.
Re: IPMA DivAll
I think that the partition of the managers line is in the css of the normal phones. Only the IPMA RP should be in in the css of the normal users phones ?!
Bye
Jo
219
