IPMA & Extension Mobility CUCM 9.X
                   I have configured Unified Assistant (IPMA) with Extension Mobility with CUCM 9.x All the users have user device profiles and I hae subscribed them to the EM Phone service and the profiles are associated with end users. However when i try to configure the user for manager I cannot select anything under the drop down Device Name/Priofile. I have also ticked the Mobile Manager tick box.  If i associate a hard phone with the user then it is available but this defeats the purpose. Also can the assistant use Extension Mobility? This configuration does not allow you to select device profile under assistant configuration. Any help would be much appreciated
Everyone's tags (2)
Found the answer. I'm using DX-650 and 9971 Phones and seems like they are not supported. Added a test profile with the different phone model and I can see that. Anyone know if this is in the Road map?
Roadmap questions cannot be addressed here, you need to engage your AM for that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi.
I'm trying to get this working too, can I ask where you got the info from that it doesnt work.
I'm running CUCM 8.6.2 and can't get it to work,
Many thanks,
Rob
Is there a list of models that are supported with IPMA and extension mobility. I tried with 8945s since that what the customer ordered but I have the same problem.
8945 IP phones do not support IPMA. You can check the features supported by each model of IP phone by navigating to 'Cisco Unified Reporting' on CUCM web page and then click on System Reports > Unified CM Phone Feature List , select the phone model and 'All' in features dropdown and it will show the results.
Manish
855
