IPMA in a large company environment
Does anyone actully use IPMA in a large company environment? I was always under the assumption that once you ran the wizard you were stuck and for example if you created a Route Point for IPMA with 2XXX all of your Managers and Assistants DIDs need to be in the 2XXX range. How do you guys use this in a large environment where Managers and Assistants have radically diffrent extensions. For example I have a Manager whose ext is 8701 and an Assistants that is 3597...what do I do there? Thanks guys.
Green
Re: IPMA in a large company environment
Create a route point but add multiple dn patterns under it. Even though IPMA
supports only one RP but it does support multiple dn patterns.
Do you mean in its calling search space place the partions where all the phones are? Your term "dn patterns" is what is confusing me.
111
