08-13-2009 05:34 AM - edited 03-15-2019 07:20 PM
Hy,
It's possible to configure IPMA intercom auto answer off on CUCM 7.0
08-19-2009 09:22 AM
You can choose one of these options to activate the Auto Answer feature for the directory number:
Auto Answer Off
Auto Answer with headset
Auto Answer with speakerphone (intercom)
08-19-2009 09:44 AM
Thanks.
In CM version 7.0.1 in intercom directory i don't have option auto answer off, just auto answer with headset or speakerphone.
For intercom it's possible auto answer off or not?
08-19-2009 09:23 AM
When you create a script in 4.0(4) SR1 it will serialize every step in the script and each step will have some version number. Now when you open the script in 4.0(4) editor then it will try to de-serialize every step and in Time of Day Step the version numbers are different. If you create a script in lower version and try to open that script in higher version then it will work but other way round may not work because of this serialization issue.
Check the bug for workaround: CSCsg77311: Failed to load script file; com.cisco.io.IOException: unread
12-01-2009 06:35 AM
Follow up question on this:
I haven't see any on how to configure IPMA intercomm lines.
Do you configure the same as regular intercomm?
12-01-2009 07:01 AM
Hi SmallRain,
These IPMA Intercoms are not the same as a "regular" Intercom, here
is a config example
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_1/ccmfeat/fsipmasl.html#wp1072258
Cheers!
Rob
12-01-2009 07:19 AM
Rob and Smallrain,
With the later versions it depends on the phone model - 7940/60s are done the old way, the newer models use Intercom keys, which are the same as normal intercom keys. From the 7.0 Features and Services Guide:
Manager Phone Configuration
Configure the manager Cisco Unified IP Phones with the following settings:
•Standard Manager softkey template
•Primary line
•Additional lines if required
•Voice-messaging profile on primary line
•If using the Cisco Unified IP Phone 7941, 7961, 7970, or 7971, configure the intercom feature
•If using the Cisco Unified IP Phone 7940/60, configure the incoming intercom line to support the auto answer with speakerphone or headset option
•If using the Cisco Unified IP Phone 7940/60, configure the speed dial for outgoing intercom targets
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fsipma.html#wp1071963
Happy Trails,
Art
12-01-2009 07:30 AM
Hey Art,
Well, you learn something new every day
+5 points for posting up this great info.
Cheers!
Rob
PS: I'm sure the 5 will show up sometime. This new rating system
has some real quirks.
12-01-2009 07:34 AM
Rob,
NP - happy to help. I've learned a bunch from your posts too.
Just struggled through the newer version of IPMA so it was fresh in my mind.
Onward and Upward!
Art
12-01-2009 06:59 AM
I am running 7.0 and I have the same display you do - no option to turn it
off, only speaker and headset.
If you really need it off I would suggest you set up a normal (internal) line just like we used to set up for the intercom function in IPMA prior to CCM having intercom.
If you don't want to go that route there is a service parameter for delaying the auto-answer function, but it is global:
HTH,
Art
