Community Member
IPMA issue
Hi all, im' deploying CallManager 6.1 and i was trying to configure IPMA using shared line appearance but i got the same prob as in CCM v4.1, when i'm trying to access the following web page :
http://172.16.0.254/ma/desktop/maLogin.jsp
it just displays : System Failure
Note that i'm depolying the CCM in MCS Server as a stand alone server
Green
Re: IPMA issue
Could you please upload your IPMA logs for server and client
Do you see C:\Program Files\Cisco\MA\LDAPConfig.ini
also upload it
thanks
Using AD integration?
Community Member
Re: IPMA issue
Thanks for your reply, i just fixed :) by re-create the manager and the assistant thanks again
108
