IPMA services
I would like to know what service I have to restart in the cucm for IPMA , i have a cucm 8.6
Thanks.
1 ACCEPTED SOLUTION
Guess you didn't check
Guess you didn't check feature services, because that's where it is.
java
if this helps, please rate
www.cisco.com/go/pdi
IPMA service, the
IPMA service, the configuration guide covers required services for IPMA
java
But I dont see it in the cucm
But I dont see it in the cucm.
I know i have to restart also the tomcat services.
thanks.
Where are you looking for the
Where are you looking for the service???
java
Serviceability  Tools Control
Serviceability
  Tools
 Control Center - Network Services
java
Jaime,Im checking the feature
Jaime,
Im checking the feature services and I dont see it.
THanks.
You may need to activate the
You may need to activate the service under Tools->Service Activation.  It's called "Cisco IP Manager Assistant" under the "CTI Services" section.
60
