IPMA Tomcat service
richb1971
Level 4
Level 4
Once the IPMA application has been removed from Tomcat how do you reinstall it? Can I just enter the "Path,Config URL,WAR URL"? If so,how?
kdamisch
Was this ever resolved? We have a similar issue where extension mobility was removed from the Tomcat Web Application Manager (instead of reloading it).
Kevin
Easily done. Did it myself recently (removeed IPMA). Unfortunately no one replied so problem is still outstanding-cannot access Tomcat.If you manage it I'd be grateful for a reply Kevin.
On the upside of your problem-I believe rebooting the CCM will recover EM.
Good luck
Rich
