IPMA
Can a phone be used as assistant console in IPMA in cases where assistant doesnot have a PC.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: IPMA
Yes, this is available in CM 4.2/4.3 as well as CM 6.X/7.X
HTH,
Chris
Re: IPMA
HTH,
Chris
Re: IPMA
Cderen,
I dont doubt of your answer and indeed i've tried this function in some versions of ccm and its only possible from 4.2.
Do you have any document that shows the inclusion of the functionality from 4.2?
thanks,
Met.
Re: IPMA
From CM 4.2.1 release notes
Cisco recommends that an assistant use the Cisco IPMA-on-phone features only if that assistant supports no more than five people.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/4_2/cucm-rel_notes-421.html#wp2437923
look through CM Admin/Feature and System guides for more info.
Chris
Re: IPMA
Thank you very much cderen.
5 points for the fast and objective response.
Met.
Re: IPMA
Chris,
Thanks for your answer. Is this fearure in CCM5.X too?
Re: IPMA
No, CM 5.X does not have any of the new CM 4.2 features.
Chris
Re: IPMA
Sorry but controling IPMA from the assistant phone without the pc console is possible in 5.x. Been there, done that.
Hope this helps!
Met
Re: IPMA
Hi !
I tried IPMA service in the assistant phone [ CUPC] it's won't working.
Assistant Phones subscribed the IPMA service.
whether IPMA-on-phone services only for Manager,or it's depends on device model.
CUCM version 7.1.2  CIPC version 2.1.2
210
