IPMA
hi all,
i'm configured IPMA with proxy line to a manager and his assistant, but the problème is when someone call a manager the call is not routed to assistant automaticaly, the manager phone ring 3 or 4 time and then the call is routed to assistant.
i want that the call be routed directly to assistant, how can i do that.
thanks a lot
Silver
Re: IPMA
It looks like a partition problem also look at the CTI RP intercept is the manager DN in that CTI range. Have you check the CFNA setting on the manager as well ?
Re: IPMA
thank you for response,
but i dont know how to verify what do you say.
can you explain plz
119
