04-26-2012 07:17 PM - edited 03-16-2019 10:51 AM
Hi friends!!
I would like know if I can log in 7937 with extension mobility on CallManager 5.1.
When i try to create device profile, i dont have the oprtion for device 7937.
Do they are compatible?
Solved! Go to Solution.
04-26-2012 07:23 PM
Yes it is compatiable.
You can use the below troubleshooting guide,
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080a80386.shtml
Hope it helps.
Anand
Please rate helpful posts !!
04-26-2012 07:23 PM
Hope it helps.
Anand
