IPT Integration with BP250
In my offic I established a IPT with UCM 6.0 and 2811 Router as Gateway.
Please help me with integration new IPT and the existing Ericsson PBX BP250 for PSTN connectivity.
Please suggest me the interface types and type of connectivity at bothe ends(2811 ISR and BP250) fot one or 2 lines.
Sri
1 REPLY
Hall of Fame Super Gold
Re: IPT Integration with BP250
Use ISDN BRI if available on the PBX, second choice analog E&M, last choice FXS/FXO.
However, it would be better if you connect the 2811 directly to PSTN, you will find that is difficult to make the connection to PSTN via a PBX.
157
