Community Member
IPT issue
Hi all,
sort of a non technical way of askin..am facing an issue with my ip phone registered with the remote data center call manager..i'm able to hear what the other side is talkin, but they are not able to hear what am talkin..there are not routing issues as far as i know..
please put in your comments on possible areas to check..
thanks
Community Member
Re: IPT issue
hey all,
this is the config used in the port connecting the ip phone..
interface FastEthernet0/41
description End User Connection
switchport trunk native vlan 80
switchport trunk allowed vlan 80,90
switchport mode trunk
mls qos trust device cisco-phone
mls qos trust cos
and the belwo are the vlan configs
interface Vlan70
description Transit_VLAN
ip address 10.191.28.8 255.255.255.240
standby timers 1 3
standby 70 ip 10.191.28.7
standby 70 priority 110
standby 70 preempt
interface Vlan80
description Data_VLAN
ip address 10.135.6.2 255.255.255.0
ip helper-address 10.135.6.252
standby timers 1 3
standby 80 ip 10.135.6.1
standby 80 priority 110
standby 80 preempt
interface Vlan90
description VOICE_VLAN
ip address 10.135.7.2 255.255.255.0
ip helper-address 10.201.65.81
standby timers 1 3
standby 90 ip 10.135.7.1
standby 90 priority 110
standby 90 preempt
the phone is working(can hear only one side though) only when i configure it in data vlan range..with vvlan 90 ip addr, not even able to ping.
thanks
Silver
Re: IPT issue
You need to verify your routing and security setup here.
If you can not ping from voice vlan, then either your routing is not right. Or you have a firewall in between, and it is blocked.
Either way, you need to verify routing and whether there are any firewalls in between and whether they are configured correctly.
Cheers,
Tim
Re: IPT issue
Looks like one way voice issue. Have a look at the following link for troubleshooting -
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a008009484b.shtml
This could be becasue of NAT as well. Its discussed in the above link.
-> Sushil
134
