IPT Solution BOM
I am planning to build an IPT solution and need your kind assistant to come up with the BOM, underneath my requirement
1.Call Manager (Hardware, Software and licenses) - hardware preference is UCS and CUCM version 9 or 10 = Qty:1
2. Unified Messaging (Hardware, Software and licenses)  = Qty:1
Note
1. # of ip phone is 1200
2.hardware preference is UCS
Hope to receive your kind response.
Everyone's tags (1)
VIP Purple
Hi,you need to order the
you need to order the following as per your requirement
a. CUCM  : the part codes for restricted CUCM-VERS-9.Xand unrestircted CUCM-VERS-9.XU
b. also, need to order licenses as per user : BAsic/Enhanced/Enhanced Plus/CUWL standard
c. for messaging, part code is UNITYCN9-K9. for basic messaging UNITYCN9-STD-USR and enhanced UNITYCN9-ENH-USR
d. Further, also need to have upgrade order through UCSS for any future major migrations
the best would be to contact Partner who can run Cisco Commerce Workspace for ordering.
you can also use ordering guide
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/uc_og_ucl_cucm_mcs_cer.pdf
regds,
aman
Hi Amon,Good day!Kindly
Hi Amon,
Good day!
Kindly please also provide the hardware product # for CUCM and Unity, my preference for this one is UCCS.
Thanks and regards,
VIP Purple
Hi, you can refer DOCWiki
you can refer DOCWiki links
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware#UC_on_UCS_Tested_Reference_Configurations
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware#C220_M3S_.28SFF.29_TRC.231
regds,
aman
81
