Community Member
IPT using Cisco 2811 Router and express 500 catalyst switch
I need to config IPT for my phone to be connected to the outlet and my pc connected to my phone.
Can someone help me with guides to use to get this done.
My 2811 router is facing the internet, I have VPN configs on it, behind the router, sits my switch and every other users connects to this switch, also I have a DHCP server and want this server to assign IP Addr to both the IP and PC.
Please anyone who has done this before should assist with links to docs.
Thanks in advance, cheers.
1 REPLY
Re: IPT using Cisco 2811 Router and express 500 catalyst switch
How to configure a Catalyst switch port to connect to a Cisco IP phone
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K33524366
Voice VLANs and IP phone support on Catalyst switches
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K14820688
How to configure a Voice-over-IP (VoIP) network on the Cisco Catalyst 6500 series switches
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K16958673
java
if this helps, please rate
java
www.cisco.com/go/pdi
152
