Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
is a fractional T1-CAS with MGCP supported in call manager?
Hello all,
I have a customer that has a fractional t1, not a pri and we are moving it over to a 2821 router. We want to use MGCP
I have a tac case open, the engineer first said it wasn't supported but then realized i was refering to a t-1 cas. He then said it was supported and gave me a link (to version 3) we are on version 6.1.2
I configured it on the call manager. After i configure the ports however a link to ADD a DN shows up next to each port. Am i experiencing a bug? or do i need to assign a DN to each T1-CAS port?
that doesn't seem right.
any help would be great
thanks!
Bronze
Re: is a fractional T1-CAS with MGCP supported in call manager?
Hi Ken,
Fractional T1-CAS is supported in CUCM 6.1, and no, you shouldn't have to add a DN to each port so something is askew.
Try this link rather than the version 3 one
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/6_1_1/ccmcfg/b06gtway.html#wp1311387
regards,
Paul
thanks for the link Paul.
I thought something weird was going on when i saw an Add-DN link.
I'm going to give it another shot in the morning
I think i might be running into a bug.
When i add the t1-cas and the ports it has a link to ADD-DN next to each port.
They are running cm 6.1.2.1000-13
however if i add the same gateway on another call manager (at another customer site) running 6.1.3.3000-1 it does not have the ADD-DN link next to the ports.
think its a bug?
Bronze
Hi Ken,
it certainly sounds like it though I can't see any Bug IDs like it reported in the Bug Toolkit.
You could log a TAC case about it, but it looks like you've already discovered the solution to the problem, and that updating to at least 6.1.3.3000-1 is likely to resolve the issue.
regards,
Paul
542
