Community Member
Is an ATA 187 compatible with UCM 10.5?
I can't find any reference to compatibility of an ATA187 with UCM 10.5.
(although I can find reference to ATA 186/188 models - which are no longer compatible).
Has anybody tried this, or have you found a reference to this?
1 ACCEPTED SOLUTION
Purple
Hi Craig,Yes,it is supported
Hi Craig,
Yes,it is supported.
You can refer the link
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
regds,
aman
Purple
Hi Craig,
regds,
aman
Community Member
Thanks - that's a good guide
Thanks - that's a good guide.
There is conflicting compatibility information - perhaps UCM 10.5 release information is still being updated.
Purple
Hi Craig, One doubt has come
Hi Craig,
One doubt has come in to my mind while referring  the same link which says 9.3(1) version is compatible with CUCM 10.5 but when I click on downloads software option , I get only 9.2(3) as latest.
I think it is not updated.
regds,
aman
Community Member
Aman,Thanks - I see what you
Aman,
Thanks - I see what you mean.
9.2(3) is already quite old - released in Dec 2011.
Maybe they are getting ahead of themselves.
Or it's a cut-n-paste error - they mention the same firmware for 6900 series phones.
Hmmmm.
817
