Is Cisco 2821 Router a Voice gateway?
zeeshan.a
hi all,
this is my first post in the forum,
i want to know if Cisco 2821 router a voice gateway also? or should i have to add some module or wic? A PRI will be terminated at 2821.
please advise
thanks
2 Accepted Solutions
Remember you also need PVDM2 that is the required DSP resources, to use router for VoIP. Do "show diag" to know if you have it and what "size" it is.
8 Replies 8
allan.thomas
Level 8
Level 8
The 2800 Series ISR gateway certainly support voice, take a look at the document at the following link it refers to the various gateways interoperability with CallManager:-
http://www.cisco.com/application/pdf/en/us/guest/products/ps259/c1650/cdccont_0900aecd8057f2e0.pdf
Hope this helps
Allan.
thnx,
i have 2811 with E1 card for PRI, so i can directly connect IP PBX to this Router for VoIP.
yxsjwsb
And once you get the router set up, go get the E1 Pri debug demo from pippinsoftware.com , it's handy for troubleshooting.
thanks
one more thing with PVMD2, does 2821 support SIP?
Yes.
thanks a lot
