Is Cisco IP Phone 7962G compatible with CallManager 4.1(3)
Is Cisco IP Phone 7962G compatible with CallManager 4.1(3)? If yes, how do I add the configuration for this phone to Call Manager?
Bronze
Re: Is Cisco IP Phone 7962G compatible with CallManager 4.1(3)
Yes, but you need at least CCM4.1(3)sr5b, I'm using CCM 4.1(3)sr6.
Go to Device->Add new device->Select the model and configure the values (MAC, Dev Pool, DN, CSS, Partition, etc).
All the best
David
Just 4.1(3)SR5 is not enough, you need a minimum DevPack.
Table 1 Minimum Required Device Pack Version
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7962g_7942g/firmware/8_3_2/english/release/notes/62832.html#wp42233
4.1(3)SR5
ciscocm.4-1-DevPack-55
java
if this helps, please rate
java
www.cisco.com/go/pdi
497
