Community Member
Is CUCM supported on VM?
I have a customer wanting to install a subscriber on VM instead of a hardware appliance. Is this supported? I heard rumors that it is. If so, what version of CUCM is supported using VM Ware?
1 REPLY
Re: Is CUCM supported on VM?
No, it's NOT supported.
None of the available versions are supported on VMWare.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
212
