Is direct in dial via ISP only supported via DID voice interface cards
If you have a DID feature from an ISP, can you only use a DID based voice interface card?
Thanks in advance again :)
1 ACCEPTED SOLUTION
VIP Purple
Yes, you can do that.You need
You need to configure did signal on that particular voice port.
Please refer the link for same
http://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did-fxs-fxo/24760-confg-vic-2did.html
regds,
aman
thats true.in analog voice
thats true.
in analog voice port, FXS-DID are famous.
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/15268-vic-2did.html
~chintan.
VIP Purple
Hi John, You can also refer
Hi John,
You can also refer the link
http://www.cisco.com/c/dam/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd8057f2e0.pdf
regds,
aman
VIP Purple
Hi John, you can also refer
Hi John,
you can also refer the link
http://www.cisco.com/c/en/us/products/collateral/routers/2600-series-multiservice-platforms/product_data_sheet09186a00800921e7.html
regds,
aman
Thanks Aman. I had seen that
Thanks Aman. I had seen that link.
Can DID devices also be used for connecting Cisco phones to routers?
VIP Purple
Hi John, DID is a basically a
Hi John,
DID is a basically a service which is offered by TELCO and same needs to be supported on Voice cards.
on these cards , you have voice ports and not ethernet ports.
Cisco IP phones need to be  connected to switch.
regds,
aman
That's correct.And then  I
That's correct.
And then  I guess configure vic-2did in router to receive did calls from ISP. Correct?
VIP Purple
regds,
aman
Thanks Aman. Much appreciated
Thanks Aman. Much appreciated. You have made the complex simple smiley
VIP Purple
Thanks for rating. [+5] to
Thanks for rating.
[+5] to Chintan for knowledge sharing.
regds,
aman
Thanks for your reply Chintan
Thanks for your reply Chintan.
And this would apply to a small business using Cisco phones and routers if they wanted to use this method too then?
And 1 port could be for fax
And 1 port could be for fax and the other for voice or both could be used for voice then
ports can be used as FXS or
ports can be used as FXS or DID,
if you are planning to use them as FXS then you can attach fax or telephone or both.
regards
Chintan
Thanks Chintan, No, I was
Thanks Chintan,
No, I was considering Cisco phones attached to routers.
35
