Is DPA 7630 Hybrid Integration required?
Customer has current Octel 250 integrated with Avaya S8700. I'd like to keep that in place and do a new Simple Integration with new PIC card on Octel 250/DPA7630 to CallManager. Is that possible? I seem to recall in Octel 250 you can assign users to which "PBX" or integration link their mailbox is on but it has been a long time since I worked on a Octel 250.
Or is Hybrid Integration going to be required?
http://www.cisco.com/en/US/products/hw/gatecont/ps821/products_administration_guide_chapter09186a00800b7055.html#xtocid9
Hall of Fame Super Red
Re: Is DPA 7630 Hybrid Integration required?
Hi Jason,
I believe the "Hybrid" integration will be required here. We still run an Octel 250 with DPA 7610/Nortel/CCM integration. In the Octel user config there is not a method to assign the PBX that the user is assigned to. The only way to differentiate (sp?) between the two systems is via the Port config on the Octel. This is where the Ports are split to reference either the Avaya or CCM/DPA routing.
Hope this helps!
Rob
In the Octel Port Config, can I have two seperate MWIs? One for CCM, other for Avaya G3? But I guess issue is still User Config you can't tell it which MWI to use.
Hi Jason,
It's a little hard to explain, but, in this type of integration the DPA handles all MWI requests for both systems.
From the doc you linked have a look at this section;
DPA 7630
To use this configuration, all MWI lines for the Definity and Cisco CallManager systems must pass through the DPA 7630(see Figure 2-5).
For example, on our setup , the first DPA has Ports 15 and 16 configured for MWI. These ports are configured as such in the Octel as well and provide MWI for phones/users attached to both systems.
Hope this helps and makes some sense!
Rob
104
