Community Member
is DTMF debugging on ISDN PRI possible?
Hi!
Is it possible to debug DTMF event ( when gataway receive/transmit DTMF tone over ISDN PRI ) on 28XX/29XX/5350XM  gateways?
On analog FXO ports there is a 'debug vpm signal'  command
I looking similar coommand for PRI tone debugging ...
/lexxa
Everyone's tags (3)
VIP Super Bronze
Lexxa7777
Yes this is possible..here is the debug:
debug voip rtp session named-event
Please rate useful posts
"I am complete in God, God completes me"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
Hi aokanlawon, thanks for you reply
but 'debug voip rtp session named-event' shows that gateway send/recieve dtmf event on VOIP  call leg as NTE event ( when configured dtmf relay rtp-nte )
I need a debug on POTS leg, when gataway recieve a tone in B-channel
I have a strange case. Sometimes digits duplicate and I want to control what gateway really recieves in B-channel.
/lexxa
VIP Super Bronze
Try this..
debug vtsp dsp:
shows the digits as they are received by the voice port. The following output example shows the collection of DTMF digits from the DSP:
!-- Caller entered digits 5000.
!-- The DSP detects DTMF digits. Digit 5 was
!-- detected with ON time of 130msec.
*Mar 10 17:57:08.505: vtsp_process_dsp_message:
MSG_TX_DTMF_DIGIT_BEGIN: digit=5,
*Mar 10 17:57:08.585: vtsp_process_dsp_message:
MSG_TX_DTMF_DIGIT_OFF: digit=5,
duration=130
*Mar 10 17:57:09.385: vtsp_process_dsp_message:
MSG_TX_DTMF_DIGIT_BEGIN: digit=0
*Mar 10 17:57:09.485: vtsp_process_dsp_message:
MSG_TX_DTMF_DIGIT_OFF: digit=0,
duration=150
*Mar 10 17:57:10.697: vtsp_process_dsp_message:
*Mar 10 17:57:10.825: vtsp_process_dsp_message:
duration=180
*Mar 10 17:57:12.865: vtsp_process_dsp_message:
*Mar 10 17:57:12.917: vtsp_process_dsp_message:
duration=100
Community Member
Thanks for right direction
debug vtsp dsp:      seems like working on analog ports
but debug voip vtsp session  ( on 5350XM)   shows digits during mid-call
Jun  6 13:56:50.521: //5004160/xxxxxxxxxxxx/VTSP:(3/1:D):30:0:0/vtsp_dsm_digit_begin_cb:     Begin Digit=5
        Digit Reporting=FALSE, Digit Consume=FALSE, Digit Relay=TRUE
Jun  6 13:56:51.537: //5004160/xxxxxxxxxxxx/VTSP:(3/1:D):30:0:0/vtsp_dsm_digit_end_cb:       End Digit=5
btw debug voip vtsp tone shows nothing
Community Member
debug voip dsm dsp (new version of debug vtsp dsp) doesn't provide any digits on 3945 PRI.
neither does debug voip vtsp session
6083
