Community Member
Is iLO the same as Terminal Server?
Hi, I want to install the Windows updates using the serverupdatewizard on IPCC server. I know that we can not do this through terminal server. I just want to confirm that iLO is not a terminal server and I can use the serverupdatewizard through iLO.
Can someone confirm?
sienz
1 ACCEPTED SOLUTION
Red
Re: Is iLO the same as Terminal Server?
iLO extends the monitor and keyboard to your Windows desktop. It's not a terminal server. It's more like a KVM (or IP KVM).
You may do anything as you were sitting in front of the physical server.
Michael
http://htluo.blogspot.com/
1 REPLY
Red
Michael
138
