Is it possible on an ISE/CME to play a prompt but disabling recording
danjor
using a ISR1861 with his factory ISE.
IOS 15.0(1)M3 / CME 7.1
Unity Express on ISE 7.0.5
Is it possible to personalyse a voicemail prompt with a message and play the voicemail prompt but without giving to the caller the opotunity to record a message (for exemple just to let te caller now a situation like "away" or something else ?
I know I can do it with IVR and personalised greatings but as I have only standard default one possibility, I would like to hold them for other application.
Thanks for a short answer...
Daniel
You don't need to copy installation files before upgrade.
All can be done with a single command.
Then if still trouble, do a backup and install from scratch.
11 Replies 11
paolo bevilacqua
Announcement only mailbox, described in documentation.
Noticelably broken in 8.0.2
Rob Huffman
Hi Daniel,
Just to add a little reference to my friend Paolo's good thoughts
here (+5 "P") Happy New Year
Configuring an Announcement-Only Mailbox
Beginning in version 7.1, you can configure announcement-only mailboxes. These mailboxes can play the user greeting and disconnect the call only; they cannot take any messages from callers or send messages.
Announcement-only mailboxes enable you to:
Perform any operations that can be performed on a greeting in personal mailboxes, such as recording or deleting.
Use all the new greeting types introduced by the multiple greeting feature. For more information, see the Configuring Multiple Greetings.
Configure a General Delivery Mailbox as an announcement-only mailbox.
Also, announcement-only mailboxes:
Cannot be part of everyone's list (9999)
Are counted against the mailbox license
Have a default size of 5 minutes when they are created, but the default size can be modified later
Because announcement-only mailboxes cannot send or receive messages, you cannot:
Create distribution lists for them
Configure notification devices for them
Therefore announcement-only mailboxes cannot:
Have messages addressed to them
Have notifications cascaded to them
Receive broadcast messages
Subscribers can log in to announcement-only mailboxes using either the TUI, VVE, or IMAP. However, there is no reason to use IMAP to log into announcement-only mailboxes because they do not contain messages.
The following features are available only for personal mailboxes and cannot be used with announcement-only mailboxes:
Message expiration time
Message size
Fax configuration
The following operations are available only for personal mailboxes in the TUI and VVE and cannot be used with announcement-only mailboxes:
Playing new, saved, or deleted messages
Sending messages
Setting message parameters, such as configuration lists or notification devices
SUMMARY STEPS
1. configure terminal
2. voice mailbox owner name type announcement-only [size seconds]
3. end
4. show voicemail detail mailbox name
DETAILED STEPS
Command or Action
Purpose
Step 1
configure terminal
Example:
se-10-0-0-0# configure terminal
Enters configuration mode.
Step 2
[size seconds]
se-10-0-0-0(config)# voice mailbox owner user-8 type  announcement-only size 60
Creates a mailbox that cannot be used to leave messages. It can only be used to make announcements.
Step 3
end
Example:
se-10-0-0-0(config)# end
Exits to privileged EXEC mode.
Step 4
Example:
se-10-0-0-0# show voicemail detail mailbox user-8
(Optional) Displays information about a mailbox.
Examples
The following is sample output from the show voicemail detail mailbox command:
e-10-0-0-0# show voicemail detail mailbox User-8
Owner:                                       /sw/local/users/User-8
Type:                                        Announcement Only
Description:                                 User1 mailbox
Busy state:                                  idle
Enabled:                                     true
Allow login without pin:          no
Mailbox Size (seconds):          300
Play Tutorial:                    false
Space Used (seconds):          17
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/administrator/AA_and_VM/guide/vmconfig.html#wp1042523
So, you may need to move to CUE 7.1 to fully accomplish this.
Cheers!
Rob
Thanks for the help... I did upgrade to 7.1.7 and folowed the indication on CCO to do it.
So it takes all the needed files from ftp directory but at the end, the ISE was looking for a GB language file that where not present (as I put the FR language in the directory).
The download status was also not done but with an error to get this file.
I did the try to download software ... the cue-vm-fr_FR-langpack.ise.7.1.7.prt1 file and it makes an error after validating package signature:
ERROR: invalid package.Please verify if this is a valid package file
As it was to download on Cisco under the same ISE download location as the main file, I expected it is the right one. Is there an other file to download for French languages as those above?
Cheers,
Daniel
PS: I had the same error before upgrading to 7.1.7 with my older version 7.0.1 but I couldn't find an other language file for French than tose type of files.
I have seen already that some CUE files are wrong.
You can only try a different version, or contact Cisco for a resolution.
Please remember to rate useful posts clicking on the stars below.
Same for 7.1.6 and 7.1.1....
I did then download the GB file as the upgrade process did ask for it and the download di then finished without error.
The software download status shows the action on done without error.
A show software download directory shows empty directory
And after relogin in the ISE, I see that I'm still under version 7.0.5 as the process wasn't completed.
A reload let the ISE still on 7.0.5.....
Don't know what to do next....
Cheers,
Daniel
The dowload done for 7.1.7. The files are present but I did not start the command install before reload. That was why I hade an empty directory...
Now, the files where present on the ISE and after install package still not working as it makes now an error on installation.
I'll try some other version but I have to do it out of business hours as I did disturb them a lot yesterday with many downloads.... So if I do not have aanswer with the loaded version 7.1.7 before this time, I do try 7.1.x
As the system is not in se but some configs where done, I did do an upgrade.
Does a full new installation have more chance to work?
Do I have to make a backup before upgrade or can an upgrade work without previus backup?
THere is the full output from download and install:
se-192-168-92-2# $1.135.40/cue-vm-k9.ise.7.1.7.pkg user djo pass toto
WARNING:: This command will download the necessary software to
WARNING:: complete an upgrade. It is recommended that a backup be done
WARNING:: before installing software.
Would you like to continue? [n]y
Software install using RAM
Downloading ftp cue-vm-k9.ise.7.1.7.pkg
Bytes downloaded : 197403
Validating package signature ... done
Validating installed manifests .............complete.
- Parsing package manifest files... complete.
- Checking Package dependencies... complete.
Downloading ftp cue-vm-langpack.ise.7.1.7.pkg Bytes downloaded : 1205811
- Checking Manifest dependencies for subsystems in the install candidate
list..
- Checking Manifest dependencies for subsystems already installed...
complete
Starting payload download
File : cue-vm-full-k9.ise.7.1.7.prt1 Bytes : 91059526 Validating payloads match registered checksums...
- cue-vm-full-k9.ise.7.1.7.prt1
.......................................................................................verified
Extracting install scripts ...
starting_phase:
install_files.sh /dwnld/.script_work_order add_file /dwnld/pkgdata/cue-vm-full-k9.ise.7.1.7.prt1 15 /dwnld/scripts/e2e81cc6-39b5-47e1-9f83-b83c897fc50c
usr/bin/products/cue/lang_ui_upgrade_script.py tgz add_file /dwnld/pkgdata/cue-vm-full-k9.ise.7.1.7.prt1 9
/dwnld/scripts/9f112eb1-6f58-4dd4-8faa-8530467af3b9
usr/etc/tomcat_post_upgrade.py tgz
add_file /dwnld/pkgdata/cue-vm-full-k9.ise.7.1.7.prt1 6 /dwnld/scripts/8e7823e2-0e92-4470-8860-653246345f9d
usr/bin/products/cue/callagent_post_upgrade.py tgz add_file /dwnld/pkgdata/cue-vm-full-k9.ise.7.1.7.prt1 6 /dwnld/scripts/8e7823e2-0e92-4470-8860-653246345f9d
usr/bin/products/cue/rm_cue_allapps_manifest.py tgz Scripts extraction complete.
Remove scripts work order /dwnld/.script_work_order Running Script Processor for ui_upgrade Upgrading Installed languages (2):
Installed SKU Name (new version)
* TUR CUE Voicemail Turkish (7.1.7)
* ENG CUE Voicemail UK English (7.1.7)
ui_upgrade scripts executed successfully.
se-192-168-92-2# show software download server ?
se-192-168-92-2# show software download server Download server URL is:
ftp://127.0.0.1/ftp se-192-168-92-2# sho software ?
dependencies Subsystem dependencies
directory directory
download download
licenses Terms and limits of operation
packages Programs and Options installed
versions Version information for the installed packages
se-192-168-92-2# sho software packages ?
Installed Packages:
- Installer (Installer application) (7.0.5.0)
- Thirdparty (Service Engine Thirdparty Code) (7.0.5)
- Bootloader (Primary) (Service Engine Bootloader) (1.0.3)
- Infrastructure (Service Engine Infrastructure) (7.0.5)
- Global (Global manifest) (7.0.5)
- GPL Infrastructure (Service Engine GPL Infrastructure) (7.0.5)
- Voice Mail (Voicemail application) (7.0.5)
- Bootloader (Secondary) (Service Engine Bootloader) (1.0.3.0)
- Core (Service Engine OS Core) (7.0.5)
- Auto Attendant (Service Engine Telephony Infrastructure) (7.0.5)
Installed Plug-ins:
- CUE Voicemail Language Support (Languages global pack) (7.0.5)
- CUE Voicemail Turkish (Turkish language pack) (7.0.5)
- CUE Voicemail UK English (British English language pack) (7.0.5)
se-192-168-92-2# software download status Download request completed successfully.
se-192-168-92-2# show software directory download KBytes Directory
117828 /dwnld/pkgdata
Directory listings
Directory: /dwnld/pkgdata
total 117828
drwxrwxrwt 2 root root 120 Jul 8 21:17 .
drwxrwxr-x 5 root daemon 152 Jul 8 21:16 ..
-rw-rw-r-- 1 root root 28038469 Jul 8 21:19
cue-vm-en_GB-langpack.ise.7.1.7.prt1
-rw-rw-r-- 1 root root 91059526 Jul 8 21:16 cue-vm-full-k9.ise.7.1.7.prt1
-rw-rw-r-- 1 root root 197403 Jul 8 21:05 cue-vm-k9.ise.7.1.7.pkg
-rw-rw-r-- 1 root root 1205811 Jul 8 21:05 cue-vm-langpack.ise.7.1.7.pkg
se-192-168-92-2# software install upgrade cue-vm-k9.ise.7.1.7.pkg
WARNING:: Download Server Not Configured. To install cue-vm-k9.ise.7.1.7.pkg
WARNING:: all necessary payloads must be already downloaded and present on disk.
WARNING:: This command will install the necessary software to
- Checking Manifest dependencies for subsystems in the install candidate list...
complete
Downloading payload(s) complete
The system will be brought to offline state for a brief period and will be brought back to online state automatically Calculating delta.... complete.
starting_phase:
usr/bin/products/cue/lang_ui_upgrade_script.py tgz add_file /dwnld/pkgdata/cue-vm-full-k9.ise.7.1.7.prt1 6 /dwnld/scripts/8e7823e2-0e92-4470-8860-653246345f9d
usr/bin/products/cue/rm_cue_allapps_manifest.py tgz add_file /dwnld/pkgdata/cue-vm-full-k9.ise.7.1.7.prt1 9
File transfer error during download. Protocol error code is 3 Error encountered while downloading payload(s) se-192-168-92-2#
*** Command aborted... ***
*** System state changed ***
se-192-168-92-2(offline)#
By surfing on CCO, I find indication that the licensing has changed between 7.0 and 7.1. I need new CLS files.
As the ISE is buyed with the router, I expect the basic licences are part of the equipement for the minimum of 5 user voice mail and 1 attendant or something like that...
When I do change to 7.1, is there a migration plan free of charge or does the customer  have to buy new licences? (did not find any migration indication for licensing, only compatibility matrixes and description of new licences)
I can't also remenber to get a PAK with the original router (C1861-SRTS-C-B-K9) where the ISE was installed on (I have a secod one on the same customer, but still in version 7.0... So if I do one, I have to do the second to stay on line in the NW as it is easier to manage)
On other question... what is meaned with the payload files missing above in the installation failed?
Migration license can be obtained on the cisco licensing portal, as mentioned many times already in similar threads.
Did open a TAC case.
For information, on ISE, the original licences are not to upgrade as they are part of the systeme.
The upgrade did still faile and we did install them from scratch in 7.1.7. Now it works.
Restor from backup 7.0.5 tu 7.1.7 di work fine.
Thanks all for Ur help
Very good. Thanks for the nice rating and good luck!
