Community Member
Is it possible to block numbers in Call Manager?
Is it possible to block incoming calls from certain telephone number in Call Manager?  Thanks.
Re: Is it possible to block numbers in Call Manager?
NO, read this.
Reject Calls
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
Call Blocking Configuration Examples
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
It has to be done in the GW and you need H323, NO WAY with MGCP.
Please search NetPro for answers before you post, this has been asked many times before.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
VIP Purple
If you're using an H.323 gateway, you can block calls based on calling number. See the following link. This is not possible with an MGCP gateway.
https://supportforums.cisco.com/docs/DOC-1850
Hope this helps.
Brandon
810
