Is it possible to carry data through MGCP gateway?
Hi All.
İs it possible to carry data through mgp gateway. I have searched but not able to find any documentation about this issue. Is there anyone to have any documents and guide about that.  ( gateway with PRI- 39XX series router)
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Is it possible to carry data through MGCP gateway?
Thanks for the nice rating and good luck!
Furthermore thet limitation MGCP that you can easily correct, data calls support on the VWIC is not something known to be very used.
If you have a true need of mixing data and voice calls PRI (ISDN data is kind of obsolete these days, you should look to an AS5XXX more.
Blue
MGCP is voice gateway protocol. So you can not use it to transfer data.
But  you can use PRI line if you want for data transfer by not making  it as MGCP gateway. But make sure your service provider enables data  traffic on PRI lines. Generally PRI are to be supported for Voice  traffic.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi All,
I have learned this information from Cisco Tac;
When Call Comes from any bri or pri lines. The data's bearer capability is "unrestricted digital".
MGCP gateway doesnt support Unrestıcted dıgıtal , as the D channel ıs controlled by CUCM
211
