Community Member
Is it possible to create CM Administration user from CLI mode or change the privilege for it
Dears
When you have access to OS Administration CLI, is it possible first to know all users been created on CUCM, Finally Is it possible to change any CM administration user privilege from from CLI or create a CM administration user to access CM administration mode
THanks
Purple
I do not think u will be able
I do not think u will be able to change the privilege level for the user which has been created at time of installation.
you can create new Os adminsitration user from CLI using command set account name ABCD. After u press enter, u will be asked for privilege level 0 or 1
To check for OS users , run the command show account
regds,
aman
Purple
[+5] to Manish , providing
[+5] to Manish , providing more info.
regds,
aman
Just to add to what Aman
Just to add to what Aman suggested:
The privilege level can be 0 or 1 for the new user, it can not have the same privilege level as original username. However, it does allow you access and modification privileges on OS Admin and DRS pages just like the original OS user.
Privilege level 0: Specifies an ordinary privilege level. Users with ordinary privileges can run CLI commands with privilege level 0 only.
Privilege level 1: Specifies an advanced privilege level. Users with advanced privileges can run CLI commands with privilege level 1 and below,
The administrator account that the system creates when Unified CM installs has a privilege level of 4. The administrator can run all commands in the CLI
Manish
51
