Is it possible to enable "Rtp control protocol" in cisco 7942g series xml config files?
I can see on 7942g settings menu that "Rtp control protocol" is disabled, but it is not editable and as I'm not using cucm I need to enable it some other way. is it possible to enable it from xml  configuration files?
1 ACCEPTED SOLUTION
to enable RTCP you can use
<vendorConfig>
<rtcp>1</rtcp>
</vendorConfig>
within the SEPXXXXXXXXXXXX.cnf.xml file.
<vendorConfig>
<rtcp>1</rtcp>
</vendorConfig>
Thank you very much.
107
