Community Member
Is it possible to record a call to a IP Phone 7940 in a Cisco Unified Communication Manager 11.5 installation?
We have Cisco 7940 phones, we want to see if we can record call to a one of these device.
We have Cisco Unified Communication Manager System version 11.5 installed and in the 7940 phone configuration page we can see the Built In Bridge but we couldn't find the Recording Profile of the phone anywhere in the configuration.
Is there any other option that we can use this with Cisco Unified Communication Manager System version 11.5 and to record the calls? or is there any document saying that it is not possible to record calls using this phone.
Thank You,
Best Regards,
Neminda
Silver
Re: Is it possible to record a call to a IP Phone 7940 in a Cisco Unified Communication Manager 11.5 installation?
7940 is EOL and EOS, which means, that any problem that you might encounter that relates to FW, any new features you might want, etc. won't be addressed by Cisco. Simply, because the BU does not test EOL/EOS products, and therefore, fall under NOT supported
Also the below DOC lists supported endpoints for recording/Silent monitoring, 7940 is not listed as supported there.
https://developer.cisco.com/site/uc-manager-sip/documents/supported/
Please rate if you find this helpful.
Aeby
Aeby
Community Member
Thank you very munch for the quick response. Information you mentioned in
the reply is very important regarding this matter. Thank you again.
Highlighted
Silver
Glad to be of help. If you found the post useful please do rate by clicking on the stars below the answer.
Aeby
Aeby
169
