04-24-2014 09:19 PM - edited 03-16-2019 10:34 PM
I mean.. the credential poliy is set when "User Must Change at Next Login"... and it´s do it... login is not the problem... the user can change the password by a personal password.. but when they´re logging out.. the change password bottom appears again.. is it possible to deactivate this bottom when they are logging out?.
04-25-2014 09:08 AM
In fact when the user is logging out from Extension Mobility the Iphone says:
Logout userid?
Yes No Set PIN
we would like to remove Set PIN botom, is it possible?
Regards.
03-11-2015 05:17 AM
Hi Carletters
We are facing same problem here with version 9.1.2. Customer want to prevent "Set PIN" softkey from end user.
Have u got this resolved ? It would be great if you could share resolution.
Fei
03-25-2015 02:24 AM
it is not possible to remove the option, also not in release 10
it can be a security issue aswell within the company I can imagine, if the PIN options is there.
some of my customers have been using a sso application from a company called rsconnect. they have created an em-sso and using this you can entirely remove the em ip phone services from your phone, use https and significally increase em security.
