Is it possible to rename a line group without interfering with the functionality in Cisco Unified CM Administration - System version: 7.0.1.11000-2?
In our installation "Cisco Unified CM Administration - System version: 7.0.1.11000-2" I have a lot of Line groups that needs to be updated and I need to rename them from one name to another.
Can I just rename the “Line Group Name” and do this without interfering with the functionality of the Line group?
Kind regards,
Carl-Marius
2 ACCEPTED SOLUTIONS
Super Bronze
Re: Is it possible to rename a line group without interfering wi
Yes, the name of the line grou is just that - the line group is actually linked to the hunt list via a PKID in the DB, so it will work fine.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hall of Fame Super Red
Hi Carl-Marius,
Yes, these can be re-named without issue. I just tried this out to be sure. Once
it has been updated you will also see the new name has propogated to the associated Hunt List
Make sure to always test at least one list before going too crazy on your CUCM version.
Cheers!
Rob
Super Bronze
Aaron
Hi Carl-Marius,
Cheers!
Rob
Hi Aaron and Rob,
Thank you for the fast answer! - I have just tried it and it works after I have renamed both the Line group and the Hunt list.
Thank you for your help!
Kind regards,
Carl-Marius
2345
