Is it possible to reorder softkeys in a softkey template?
Hi all,
I am using CM6.0 Bus. Edition. Since our users require DND functionality, I have their phones using the "Standard Manager" softkey template.
On 7940 and 7960 IP phones, the screen is smaller and only 4 softkeys fit on the screen, so DND is in the second page.
Is there a way to reorder the keys so that "DND" shows up in front of "Intrcpt" instead of behind it?
I tried editing the softkey template in CM Admin, but the only option button I am shown is "reset" so I can't save the changes.
Thanks!
Chris
Hall of Fame Super Silver
Re: Is it possible to reorder softkeys in a softkey template?
You need to copy one of the standard templates and then edit it, the standard templates are not editable.
Make sure to assigned the new template to the phone.
HTH,
Chris
Chris,
Thank you! I will do that.
Chris
135
