Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Is it possible to run Nortel VOIP Phones on CUCM?
One of the my Companies Sites over in Ireland has a Nortel Phone System which they are looking to upgrade to VOIP, and there is a Cisco Call Manager Cluster version 4.2 in the UK.
I'm wondering if its possible to Integrate the 2 in some way by either haviing Nortel VOIP Phones running on the CUCM over a Global WAN Link , or an a Local Voice Gateway?
1 REPLY
Silver
Re: Is it possible to run Nortel VOIP Phones on CUCM?
I think the easiest solution is to use H.323 trunk. See if the following helps.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/431470nt.pdf
MK
213
