03-25-2009 08:37 PM - edited 03-15-2019 05:06 PM
hi, i have a cme, using a PRI with a panasonic pbx, so i want to know if is it possible to send the alerting name across the signaling path. Right now, the only information crossing between the to systems is the extension number.
03-25-2009 10:18 PM
Yes, CME should send the calling name as display IE.
03-26-2009 11:05 AM
how to enable it? is there any command? and how can i check it?¡
thanks
03-26-2009 11:27 AM
int sx/x:15 or int sx/x:23 (for T1)
isdn outgoing display-ie
03-26-2009 02:37 PM
The thing is that on any IOS version I've seen, the above command is enabled by default
