Community Member
is it possible to send the alerting name using a PRI-NET5?
hi, i have a cme, using a PRI with a panasonic pbx, so i want to know if is it possible to send the alerting name across the signaling path. Right now, the only information crossing between the to systems is the extension number.
Hall of Fame Super Gold
Re: is it possible to send the alerting name using a PRI-NET5?
Yes, CME should send the calling name as display IE.
Community Member
how to enable it? is there any command? and how can i check it?¡
thanks
VIP Super Bronze
int sx/x:15 or int sx/x:23 (for T1)
isdn outgoing display-ie
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
The thing is that on any IOS version I've seen, the above command is enabled by default
135
