is it possible to specify a different URL directory service for a lobby phone?
We have a 7841 set up as lobby phone. Now we want to allow visitors to search corporate director for extensions only. I can create another directory server to contain just the extensions. But i am not quite sure if we can specify different URL for this phone only, other phones can access the URL with full information.
Please advise,
thank you
dangquangminh@vnpro.org CCIE#11897 6016 Tillsdows Dr, Mississauga,ON Canada L5N4M3
  • IP Telephony
1 ACCEPTED SOLUTION
You could try creating two
You could try creating two different ephone templates - one for normal phones and one for lobby phones:
ephone-template  1
url services 1 http://x.x.x.x/directory1.xml Directory
ephone-template 2
url services 1 http://x.x.x.x/directory2.xml Directory
ephone 1
description Corporate Phone
ephone-template 1
ephone 2
description Lobby Phone
ephone-template 2
I haven't tested this, but I see no reason why it shouldn't work. Try it out and let us know.
Cheers
Sean
You need to mention what call
You need to mention what call control you use, and version.
java
if this helps, please rate
www.cisco.com/go/pdi
CME 10.0. Thanks Java
CME 10.0.
Thanks Java
ephone-template  1
ephone-template 2
ephone 1
ephone-template 1
ephone 2
ephone-template 2
Cheers
Sean
the 7841 is running sip so i
the 7841 is running sip so i put following configs.
voice register global
 mode  cme
 url directory http://192.9.200.83/dir/main.xml
voice register template  2
 url AppDialRule http://192.9.200.83/dir/main2.xml
 url DirLookupRule http://192.9.200.83/dir/main2.xml
voice register pool  2
 busy-trigger-per-button 1
 id mac 00E1.6DBA.8EC9
 type 7841
 number 1 dn 2
 template 2
 presence call-list
 dtmf-relay rtp-nte
 username 4007 password 4007
 description Lobby Floor
 codec g711ulaw
 no vad
the phone still use the directory pointed out in global mode, not the one in template 2. Any idea?
Thank you Sean
Did you try resetting the
Did you try resetting the phone?
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
yes i did reset the phone
yes i did reset the phone several times. also did no create profile and create profile in voice register global.
it seems that the phone only receive the url directory defined in global service mode, not the one in the template.
thank you for your time.
As this 7841 is a kind of new
As this 7841 is a kind of new phone, we have following configs for the pool-type. I don't know if this is really matter.
voice register pool-type  7841
 xml-config maxNumCalls 6
 xml-config busyTrigger 6
 xml-config custom sshAccess 0
 phoneload-support
 telnet-support
 num-lines 4
 description Cisco IP Phone 7841
 reference-pooltype 6941
turn off the command url
turn off the command url directory in voice register global and everything works fine.
thank you
Great news! I was going to
Great news! I was going to set up a lab today but this saves me the trouble :)
136
