is it possible to update cups/user using AXL
Is it possible to update CUPS/USERS using AXL , it can be done through bulk administration tool but can it be done with AXL ?
VIP Super Bronze
I believe it is as long as you know the tables to update.
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Have a look at the AXL Schema
https://developer.cisco.com/site/collaboration/management/axl/develop-and-test/documentation/latest-version/axl-soap.gsp
There is a UpdateUser Request for CUCM 10.x; there you can set imandpresense and the service profile.
For older Versions you have to look at the corresponding schema.
SQL-Query would also be possible but you should be absolutly sure to know what you are doing when running SQL updates.
118
