Community Member
Is it possible to use TCL scripts on a CME router with CUE?
Hi All,
I am wondering if it is possible to run TCL scripting on a Call Manager Expres router running Ciscu Unity Express or are you limited to the Cisco Unity Auto Attendant only?
I think that I read somewhere that you were limited to the AA if using Cisco Unity; but I can not remember where I saw this so I am hoping someone here will know.
thanks very much for any help.
1 ACCEPTED SOLUTION
Silver
Re: Is it possible to use TCL scripts on a CME router with CUE?
The output of "show call application voice  | begin app_clid_authen_collect.tcl" command will display the TCL scripts and the configuration.
MK
Silver
MK
Community Member
HI MK,
Thanks very much for that.
I tried that command and it does show me the TCL used on the router.
I went back through my reading and have found the following in a Cisco Press book.
The title of the book is Cisco IP Communications Express and towards the end of chapter 9,  I found my answer.
A TCL-based AA andCisco UE should not be used at the same time on the same Cisco CME system.
If Cisco UE is present, use its AA facilities.
Use the TCL based AA features only when a pure router based solution is required and Cisco UE is not present.
regards
a
Hall of Fame Super Gold
A TCL-based AA and Cisco UE should not be used at the same time on the same Cisco CME system.
That is incorrect. Here an example from Cisco in which both are used together to provide functionalty that one system alone does not support:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080566c4a.shtml
254
