Is it possible to view calls registry from a pc?
carlostrapiello
Is it possible to view the missed calls, received calls, etc.. from a pc?. How?.
Thanks.
Zin.Karzazi
Level 5
Level 5
If you use IP Communicator then yes. With Hard Phones you can use some Remote Utility like the one here:
http://www.voipintegration.com/software
to connect with your phones and see live Missed Calls..etc. However this method is very time consuming.
Zin.Karzazi
Zin.Karzazi
Level 5
Level 5
Zin.Karzazi
