04-02-2012 07:29 AM - edited 03-16-2019 10:25 AM
Is it still possible to build a FXO to FXS call (using connection plar xxx) on Cisco 2811 VoIP router to a Cisco 2911 VoIP Router? The command works fine between 2811 VoIP Routers.
Solved! Go to Solution.
04-03-2012 06:17 AM
04-02-2012 07:31 AM
Sure.
HTH,
Chris
04-02-2012 08:24 AM
HI Chris,
Strange! The config I have works fine between 2 x 2811 VoIP routers, but using a VoIP 2911 Router no joy:(
What I'm trying to do is link an old Mitel SX2000 PABX to a remote site using FXO cards in main site and FXSs card in the remote site.
Main Site
voice-port 0/0/0
timeouts call-disconnect 3
timeouts wait-release 10
connection plar opx 200
dial-peer voice 1 pots
destination-pattern 100
port 0/0/0
dial-peer voice 100 voip
description PLAR to KA-VOIP-CIS1
destination-pattern 200
session target ipv4:172.22.241.39
dtmf-relay h245-signal
Remote Site
voice-port 0/0/2
connection plar 100
port 0/0/2
session target ipv4:172.22.241.35
04-02-2012 08:45 AM
What IOS version are you using on the 29XX?
So, I am slightly confused what are the GWs connecting to? Are the both connecting to Mitel systems on both sides? Why would one have trunk and other station port then?
Chris
04-03-2012 01:32 AM
Hi Chris,
The IOS is (C2900-UNIVERSALK9-M) Version 15.1(4)MZ
The Main site is connected to the Mitel SX2000 with 4 Long Line Extensions these extensions are for 4 POTS Telephones on the remote site.
I can get it to work using voice-port - connection trunk, but would prefer to use connection plar so that I haven't got permanent calls in place across the link. What I can't figure out is why it works between to 2811 series Routers but not using a 2911 Router!
Thanks Gary.
04-03-2012 05:55 AM
Add the following:
voice service voip
no ip address trusted authenticate
let us know if that worked.
HTH,
Chris
04-03-2012 06:16 AM
Excellent!!
Working now
Thanks Chris
04-03-2012 06:17 AM
Great!
Please remember to rate all useful posts!
Chris
