11-05-2007 04:44 AM - edited 03-15-2019 07:03 AM
Is it possible to configure a NM-4B-S/T for voice support?
I explain:
I want to use a NM-4B-S/T to connect to the PSTN on a c2811. But when I configure the dial-peer pots, there is no voice port.
Is it possible?
11-05-2007 05:32 AM
Hi Solo,
Sorry, this card is a NM - Network Module and will not support Voice :( There are some VIC - Voice interface choices that will work listed in this doc;
http://www.cisco.com/en/US/products/hw/modules/ps5365/products_data_sheet09186a0080191d41.html
Hope this helps!
Rob
11-05-2007 06:26 AM
If I want to use 4 BRI for Voice, what is your suggestion?
11-05-2007 06:28 AM
Either 2 x VIC2-2BRI-NT/TE, or an addon module for EVM, (that is useable only on 2821 and bigger router).
