is PVDM required ?
hi, i am terminating a PRI in my 2821 router, i am not using any analog interfaces, its complete digital like we have ip phones in our branch and we will use pri to forward calls to pstn, do i require PVDM ?? or just a simple PRI card will be ok ??
reply urgent plz
thanks
1 ACCEPTED SOLUTION
Re: is PVDM required ?
Yes you will need a PVDM. The least you will need is 1 DSP per PRI channel. If you are doing conferencing or transcoding, additional DSP resources will be needed for this also
hi, i have some other branches also connecting to my main site, each branch will have atleast 2 ip phones, routers on branches are 1841, so do i require pvdm on 1841 also ?? as i know 1841 doesnt support voip so the alternative is 1861 so in this case also do i require pvdm on 1861 ??
If you are not going to have PSTN lines at branches then you do not need PVDMs there.
The branch phones can use PSTN lines at main site. Also they can use centrally configured PVDM resources for conferencing etc. if you are planning so
357
